Home Forum Ask A Member Best oil &mix ratio for ’57 5.5 Johnson outboard
  • #206211
    GEORGE STEWART
      Hi, I would like a recommendation on best oil and mix ratio for a newly acquired ’57 Johnson outboard, probably not rebuilt.
      Thanks!
      #206212
        #206239
        labrador-guy
          George, welcome, to elaborate some on that mixture. The motor you have has only bushings for bearings. If you want it to last 16 to 1 will help. I only use TCW3 synthetic oil. The motor smokes at startup but when it get warm it is fine.
          dale
          #206248
            Any outboard oil rated TCW III and mixed at 16:1 will keep your motor happy.
