Home Forum Ask A Member Butt Ugly
  • #182944
      • This topic was modified 5 years ago by Tubs.
      #182946
        Wish I ran that good @ 69 years young, NOT!
        #182951
        rvdriver
          I have the Goodyear version Sea Bee.
          It needs coils, condenser etc.. where to buy?
          Also, is there a carb kit available someplace for this? This one has been sitting and I’m sure needs an overhaul.
          Thanks,
          Steve
          #182957
            Ignition parts are same as Johnson/Evinrude, available everywhere.
            I had the Sea King version. At the same time, I had a Johnson TN-xx. Both the same year and same horsepower. Same lower unit and propeller. On same boat. But the Gale Sea King would run circles around the Johnson.
            No such thing as a carb kit. If you need a float, I use a Sierra 18-7208 (mercury) float. Grind the top dome (only) off and drill 3/32″ down through the center. Good for another.65 years.
            #182959
              Might be ugly but it sure runs good!
              #182962
                #182971
                  Frank you forgot to tell him what impeller to
                  get an how to modify it so it fits. There is
                  one in Butt Ugly and it works great. I can’t
                  remember just what you said to get. I do
                  remember Ken saying its easy to do.
                  Takes the same impeller as the Johnson TN-xx models. Requires reaming out the center hole to fit the Gale drive shaft. Don’t remember the exact size offhand but it’s close. I created the tooling to do it on the lathe but never went into production because somebody else was already doing it at the time
                  #182977
                  jimk
                    I just did mine with that impeller and reamed it out with a dremil tool. Didnt take much and it fit!
                    #183008
                    seakaye12
                      Those really are sweet running models. The single and the twins. And; all you do is prime (flood) the carburetor by turning that big knob counter-clockwise….and it will most likely start on the first pull…..even stone cold.
                      #183020
                      wbeaton
                        Very nice. I recently bought my first Gale, a 1956 ELTO 12 hp. So smooth and quiet. Gales definitely deserve more respect.
                        Wayne
                        Upper Canada Chapter
                        uccaomci.com
