Home Forum Ask A Member Cam follower worn half way CD-11
  • #253705
    need2fish
      I wonder if you could replace the follower with a piece of hardwood dowel.
      #253706
        I wonder if you could replace the follower with a piece of hardwood dowel… seriously ?
        #253710
        Steve Martin
          I don’t think that wood work.
          #253712
            funny from a guy called  Steve Martin 🙂
            #253746
              conclusion…cheap fix to a gouged cam follower
              0274  side view of carb/follower … gouge is alrerady  epoxied  with steel weld
              0276   cutting the brake line 1/4 inch  tubing
              0277    cut tubing / epoxy
              0279    cut tubing installed 🙂
              maybe next one  i’ll use  2  round clips   top and bottom to allow  the sleeve to rotate on the cam follower  to  reduce friction 🙂
              • This reply was modified 4 years, 1 month ago by JACQUES.
              #253753
                3/16 round clips  below and  above the  new  “brake line sleeve”   would let it rotate 🙂    the 1/4” tubing  tubing is a perfect fit over the cam follower being   is a tad over 3/16  (about 7/32 I.D.)
                the little sleeve  rotates nicely… with a drop of oil  it would  be even better  🙂
