Home Forum Ask A Member Can this be repaired?
  • #3113
    wiscoboater
      Hi guys,
      I have some bad damage to a Mark 55 gear case. It looks like it may have frozen at some point and blew the front off the case where the bearing retainer threads in. Can this be welded up, or is it junk.
      #28103
      Pondrocket
      Keymaster
        Yes it’s toast.
        Wish I would have taken a picture of a Mark 58a I bought for the power head some time back.Seems the owner before had that same problem and did weld all the way around. They are still around hit your local meets or post a WTB ad.
        Travis
        Travis
        #28104
        jw-in-dixie
          Epoxy??
          #28107
          david-bartlett
            I have been known to say that "I can fix anything with nothing", but in this case I would not even try.
            #28111
            JOHN D.
              If your going to replace it anyway, it may be a good time to practice with those aluminum brasing rods. I have replaced a few missing skegs using that material.
              #28113
              green-thumbs
                Really good welder and machinist (seldom same person) can work wonders.
                That being said a good replacement case would be easier to find and cost less.
                As the saying goes "they are around so ask around"
                Tag and save the old case as it may be needed as a reference and as a reminder to drain before
                Winter storage.
                Louis
                #28115
                20mercman
                  I would try to weld it if I had no other choice, I have welded up several cases like that. You have to be careful to get enough penetration to make a sound weld, but too much and you blow through and then you have no threads left to work with. Not an easy repair. I do have a good case for that motor if you are looking for one. I am in Kenosha, so not too far.
                  Steve
                  #28158
                  20mercman
                    The housing I have is 1603-1568 I have to get a good look at it and get back to you.
                    Steve
                    #28161
                    wiscoboater
                      I found one Steve. I had to beg and plead with my neighbor, but he coughed one up for $50. It’s on a 59 he stripped for parts to finish another motor. I told him if he did not sell it to me I would have my dog pay his yard a visit every day while he was at work…. 😈 😈
                      Thank you for the offer.
                      #28166
                      reivertom
                        Dog poo extortion …….HUMMMMM….I’ll have to try that on my neighbors some day if they don’t quit parking in my side of the driveway…..
