I recently took the carb of a 1948 Evinrude SpeediTwin project that I have going and took it apart for cleaning. Lots of nasty crud and varnish inside so I put it in a can of Carb Dip. Just before I closed the lid, I tossed the brass float in as well.
I forgot about it for a couple days, then took the pieces out of the solution and rinsed them off. The float now had liquid INSIDE!!!
At first I thought it was a pin hole, but the card dip actually corroded the brass to the point of making it brittle and porous. Now I need a new float!
Just want to post this so others will not make the same mistake.
Anybody want a can of Carb Dip?? 😎
