Home Forum Ask A Member Cd11 tricky hose routing…
  • #308968
      Converting a CD11 to pump using the plugged channel  method behind the carb plate. Routing hoses to a side pump on the shifter side  is kind of tricky using 5/16 hoses. any special trick ??
      #308980
        When I converted my CD-11, I used Tygon tubing for the air and fuel lines due to the tight spacing.   Here’s one pic I have of the routing under the carb.
        #308983
          sounds good .. i’ll find some yellow tubing   thanks      p.s. crazy prices !!!
          #309050
            And btw, that should be 3/16″ tubing for your CD-11.
            #309057
              The air pressure pulse nipple  and carb inlet probably  but my round mikuni pump barbs are 5/16 barbs  like my cheapo* amazon side connector.  found some blue  fuel  line  in my kit box  looks like  .25  it does fit th carb and pressure barbs  but i’ll have to mcgiver them into 5/16 pump side. .
              the main  fuel hose (side connector to pump in) is rubber  5/16 and fits  ok
              so I have  2  lines to mate  (pulse and  fuel out)  to the pump barbs  I’ll figure something out or  sand  down the rims on the pump  barbs down to .25 (4/16)
              • notice the rounded  base is backwards  for a CD   Ii needed to square off the round end to flip it over and  round out the  square end !
              thanks
