Home Forum Ask A Member Champion Hydrodrive Year ID help needed
  • #177258
    bayham3261
      Hey everyone!
      I just picked up a complete but definitely non-running Champion Hydrodrive. Based on the condition and Champion C7 plugs I’m assuming it’s been sitting in a shed for a very long time. I’ve always wanted to try my hand a fixing one of the unique motors. I want to see how slow I can make my boat go!
      It is a twin model with the model/serial number is 4LHD 9344. The Old Outboard Book put this as a ’50 to ’52 model… either 7.9hp or 8.5hp. I’m assuming the serial number was sequential for the model so this would be #9,344 in production. I’m also assuming Champion made a lot of these back in the day so this was likely built in the first year of production…? so probably a 7.9hp…? Does anyone have serial #/production year info?
      I can’t seem to find any differences in the limited info I have on champions that differentiates the 7.9hp from the 8.5hp. Was the differences just a hp rating adjustment on paper? If anybody has any technical/repair/parts diagrams on this… it would be appreciated. Thanks!
      A little information is a dangerous thing!
      #177260
      7tcu
        1950-51, 8.5hp-
        #177261
        JOHN D.
          I have been wondering what the differences were between the 7.9 and the 8.5hp motors. They are both rotary and reed valve engines. I have an 8.5 motor and on the rods there are a double row of roller bearings. There are a total of 64 rollers on each rod. Don’t know if the 7.9 is the same.
          #177262
            1950 was 7.9hp
            1951-52 was 8.5hp.
            Now you got me wondering where the extra ponies came from.
            I’m looking
            #177263
              7.9hp had Scintilla magneto, 8.5hp had Phelon magneto. But I don’t think that should make any hp difference(?)
              #177264
                7.9 & 8.5 all share the same cyl head, reeds/reed plate, pistons, cylinder, and carburetor.
                #177265
                  7.9 & 8.5 also share same con rods. crankshaft, intake manifold, and head gasket.
                  I’m running out of stuff to look at.
                  Could be spark advance on different magnetos (??)
                  #177269
                  squierka39
                    I had the 8.5 and 7.9 at one time. The head on the 8.5 was much thicker visually than the 7.9. My 7.9 is the 4K model, but I think it’s the same as the early 4L .
                    #177270
                    bayham3261
                      I’ve never heard of the Scintilla magneto… did a quick google search and saw that it was associated with Bendix…? I’ll have to pull the flywheel to check out what type of magneto.
                      I took a pictures of the head and it looks unusually thick to me… how does it look to you squierka39?
                      #177273
                      bayham3261
                        here’s another pic…
