Home Forum Ask A Member Champion impeller
  • #2053
    vintagedave
      Any suggestions where to buy an impeller for a 49 Champion 4K?
      #20412
        Are you sure you need one? They are metal and never wear out (normally).
        #20413
        JOHN D.
          Some are all metal and some are the newer style rubber. There are a couple members who will redo your old one using your old hub.
          #20422
          vintagedave
            I haven’t taken it apart yet, based on the water flow I don’t really think I need one. But I’m new to outboards and I’ve read so much about replacing impellers that I thought I’d better at least be prepared for the task. It would be great if it’s metal and doesn’t need to be replaced. This little Champion starts on the first pull and runs great, I don’t want to screw it up. Thanks for the info.
            #20426
              I’m really impressed that it pumps that well (your other post & video). It must be in really good condition. Those motors usually rely on siphon action to lessen the back pressure on the water. Your missing expansion plug breaks the siphon and it still works! Like I said, I’m impressed.
              #20427
              vintagedave
                Thanks FrankR, that’s very encouraging. The motor came with a 59 Tomahawk Skimate that we’re restoring. We’re hoping to have it in the water in about 3-4 weeks.
                #20519
                  Nice motor too Wish I had one too.Frank knows what he is talking about with these guys and many more.
