Home Forum Ask A Member Chris Craft Commander
  • #227461
    Ed Andrews
      Hi I’m new here. I was hoping someone could help me find a replacement set of coils for a 1950 vintage CC Commander. I spoke with Lee Holland already so that’s not an option. I was hoping someone could recomend one the would fit and work. Thanks in advance
      Ed Andrews
      #227463
        Are the coils in the Commander Bendix Scintilla like the Challenger?
        Only thing I found in my notes was regarding the impellers……. not sure
        who’s info it is…….
        The Chris Craft Commando has a lot of similarity to the Mercury KG7.
        A little known fact is that the impeller from a KG7 will fit into the Commander…
        RICHARD A. WHITE
          Check this thread…..
          https://www.aomci.org/forums/topic/bendix-single-output-coils/
          Here is the Ebay link for the coils…. This will require some finesse but they do work.
          https://www.ebay.com/itm/NEW-Andover-Coils-P-N-9786E128-Military-Standard-Engine-Magneto-Coil-S-1-7/283716294835?hash=item420ecf18b3:g:U3MAAOSwXKdd-8Fj
          classicomctools@gmail.com
          #227468
          Ed Andrews
            Lee mentioned to me that that was the company but IDK if they are the same ones.
            Ed Andrews
            #228242
            Ed Andrews
              Richard, thank you I ordered them and will see if they work soon. Will let you know for sure if they get the motor running.
              Ed Andrews
              #228267
              RICHARD A. WHITE
                Remember, the output is NOT where the original was, so you will need to isolate it to ensure it does not arc out and ground to anything….. maybe a inner tube sliced to slide over protecting the terminal…
