Home Forum Ask A Member Chrysler 3.5 HP
  • #2535
    mogems-yahoo-com
      Hi Guys! The calendar season is winding down but there is no shortage of outboard work! I have a (1980-1985??) Chrysler 3.5 HP. If I type in the #’s (32R3G – 1384) it comes up: "serial number not found". It also links up with Mercury on Marine Engine.com. Ma Mopar should have stuck to cars and not outboards or snowmobiles! Any Help out there? Looking for a flywheel. Thanks, George 856-447-3641
      #23889
      retiredoz
        I’ll buy 32H3 – that translates to ’83. One of my aftermarket manuals lump the 3.5 (’80-’84) in with the 4-hp ’77-84, so I suspect they share some common parts..
        #23919
        mogems-yahoo-com
          Thanks my friend. AOMCI people are the best!
          #23962
          jim-moffatt
            The 3.5 and 4 hp are the same except:
            4 hp has forward-neutral shift
            4 hp has a plastic shroud over the gas tank
            bore and stroke are the same. (there may be a minor carb or reed difference to change the hp)
