Home › Forum › Ask A Member › cleaning outside oil line on OMC 50’s motors
- This topic has 8 replies, 5 voices, and was last updated 3 years, 5 months ago by
GUY SCHMIDT.
October 8, 2022 at 10:42 am #267274
These motors are getting pretty old and when you get one that hasn’t run for a long time, here is the question. Is it worth as a matter of caution to take that line off and clean it out?
I’m addressing the line that runs from the bottom main to the top bearing outside the engine. You guys that have worked on many of these older Johnsons and Evinrudes will know
how often and if ever you have had trouble with this line being clogged.
October 8, 2022 at 10:58 am #267275don’t fix if not broken…. but if you feel like it install clear fuel resistant tubing and see the action 🙂
October 8, 2022 at 1:23 pm #267277Whenever I’m doing a mechanical restoration on one of the 50s OMC classics, I’ll take that line off and blow some parts cleaner through it just to be sure it’s clear. On all the ones I’ve done, I’ve never found one that had a plugged line, even on those that sat for many years before I got it.
"Every time you remove a broken or seized bolt an angel gets his wings."October 8, 2022 at 4:20 pm #267282I’ve had the experience when I have taken off the rubber oil line on later 60’s OMC,s it actually crumbled.
Something else to watch out for.Bob D
October 8, 2022 at 6:09 pm #267284Thanks for the input….so, if your taking it apart you might as well clean it, but typically they are not clogged so if your just trying to start the motor you probably don’t need to do the added step……..now, is there any way I can be sure that oi is getting to that top bearing?
October 8, 2022 at 6:30 pm #267285to be certain use a clear line and see the fuel/oil get pushed/sucked up and in the top of the engine barb. not much else you can do
see Johnson manul RED book page 231 and others by mdl type.
experts can chime in but I doubt it would be clogged…. otherwise fuel-oil would accumulate down below and performance symptoms would eventually develop .
millions of these oiler lines work fine… can’t say I ever read anything bad happening because of a clogged one.
October 9, 2022 at 5:22 am #267323As far as the metal lines go, if you have the power head off, on the bench, it’s a pretty easy task to take it off and put it back on. When it’s mounted on a complete engine, if you decide to take it off, be VERY careful putting it back on. It is sometimes hard to get a wrench on the fittings, and the fittings will try to cross-thread, when reinstalling them. I would let a sleeping dog lie, personally.
October 9, 2022 at 12:17 pm #267333if you are apprehensive about line blockage …blockage from whatever would clog the line could just as well get inside passages to block things up to
may as well try to blow out any crud inside with some air pressure & carb cleaner while you have the line disconnected.
again.. don’t fix it if it works !
October 10, 2022 at 8:13 am #267385Thanks to all for your help…..I’ll heed your advice.
