Home Forum Ask A Member Coat the float?
Viewing 10 posts - 21 through 30 (of 50 total)
  • #42915
    vintin
      quote outbdnut2:
      I’ve done several floats with 2 coats of Aero-Gloss and have had no problems. I coat every cork float I come across with it. Of course, any old coating that’s flaking off has to be sanded lightly to get rid of all the loose stuff. I never thought of using POR-15. Does this add any significant weight to the float? The stuff I’ve seen guys put on rusty car frames looks like it goes on pretty thick.
      POR-15 goes on like water.
      I don’t expect it adds hardly any weight at all.
      #42926
      reivertom
        What about the Sig Supercoat I mentioned……anybody?
        #42989
        opposedtwin
          I have also used the aero-gloss with no problems so far. to date I have probably sealed 10-12 floats with the stuff. I sealed the cork float on my daily runner a few years back and it still runs like a champ. I lightly sand the float to get the flaky crap off and give it a very light sanding in between the 1st and 2nd coats.
          I guess time will tell……
          BUT….until someone can tell me of a better product, I will continue to use it.
          #42990
          opposedtwin
            quote reivertom:
            when I bought my aero-gloss, I looked for but could not find the sig supercoat.
            anybody used it and can give us some feedback?
            #43004
            Alan
              I’d love to see a side by side, long term test, of various products!
              Not enough to give up the time and space necessary myself, admittedly.
              After debate and research, I went with no coating at all. Just a thorough cleaning and airing out.
              I’ll drain the carb between uses; the float won’t be immersed for months at a time. I’ll of course report back on how that goes.
              Thanks to all;
              Alan
              #43027
              aquasonic
                quote reivertom:
                I have used SIG Supercoat on seven floats over the past 4 1/2 years, and to this date, there have been no problems with any of the carburetors with newly finished or refinished floats. It is a single stage finish, so I try to give the finished floats lots of curing time before contact with gasoline. That is just my experience.
                From everything I’ve read, Super Glue also works well. You just have to be careful with the application.
                Improvise-Adapt-Overcome
                #43109
                reivertom
                  quote aquasonic:
                  quote reivertom:
                  Thanks, I heard the Sig is good stuff, but I haven’t used it yet. I also have some Sig thinner so I can put it on thin and build up a few layers. Letting it set up and cure for a long time seems like a good idea, also. I guess time will tell on all the coatings!
                  #43121
                    I get the feeling we need to start buying floats instead of coating ๐Ÿ™
                    no problems yet on my own aero gloss jobs but you guys have me worried ๐Ÿ˜ฎ
                    Joining AOMCI has priviledges ๐Ÿ™‚
                    #43150
                    vintin
                      quote crosbyman:
                      Well that would be one way to make sure it’s done right!
                      But the new float must be coated with some material and it would be nice to know what it is.
                      Unless they are all plastic these days.
                      #43156
                      fisherman6
                        They aren’t all made of plastic these days. The floats for the 9.5 OMC’s are still cork.
                        -Ben
                        OldJohnnyRude on YouTube
