Home Forum Ask A Member COIL RESISTANCE
  • #2387
    tji
      Resistance on 1931 lightwin coil on 20K scale is 2.75 .Is that number OK ? Other motors I have are in the 6.6 range. Thanks Tom
      #22880
        I’m not sure of your motor but the resistance is enough to make fire. How much resistance is the primary winding & how good are the magnets. Just compare to a 50’s motor flywheel
        #22905
        kevinf
          I’m assuming that the 2.5 is accoss the secondaries and not secondary to ground or across the primaries. For a coil from an opposed twin with magneto ignition of that age I would expect a good coil to have 6 – 7k ohms plug lead to plug lead and infinite resistance from plug lead to ground. I,ve seen coil with more resistance than the 7k work well.
          #22922
          jim-moffatt
            Most good coils are in the range of 1k to 10k or 1 to 10 on a 20k digital meter scale. All values in this range will work fine. Some OMC 30s opposed twin coils have up to 15k and they work fine at that value.
