Home Forum Ask A Member Columbian Propeller L6DB?
  • #8615
    rapier
      A friend in our boat club was given a bronze 3 blade Columbian prop for his ’60 Johnson 40hp. The hub was longer and thinner than the standard big twin / 40 versions and didn’t fit. I thought it might have been an early V4 prop, but wondered if anyone here can indentify please. The markings around the hub are Columbian_F_L6DB.
      #67096
      amuller
        Columbian had a catalog of outdrive and outboard propellers, but I would not know where to find one. Maybe Michigan Wheel could cross-reference it.
        #67104
        hydrojet
          hi, in my 1964 Columbian prop catalog shows new lite line props, Gale 60 10×11 3 blade L6DB no F. Note: small hub need prop nut #309947, drive pin # 309954,cotter pin #309955, thrust washer #304576.
          #67108
          amuller
            So it sounds like early V4 prop is right on.
            #67112
            rapier
              Thanks for that, at least he can give it away, knowing what it is now & hope he can find a good home for it.
