Home Forum Ask A Member Compression question
  • #234139
    Rusted Junk
      Jack,
      I use Seafoam to stabilize the fuel In my 57 Chevy and Camaro, also in the ethanol free outboard , yard equipment fuel. I haven’t tried Miracle Oil in the crankcase of my vehicles, just to mix with two stroke oil or soak stuck rings. I like both of them,
      Steve
      #234809
      Jackson65
        I am going to try to get her assembled in the next week or so, since it is warm enough to work in my shop and outside here as well, now. I am glad to see the warmer weather, but my projects have piled up over the coldest months of winter.
        #234810
        Jackson65
          Steve,
          That makes sense. Different products for different uses, with some overlap.
          #234831
            What’s this Miracle Oil you guys are referring to? Is it the same as Marvel Mystery Oil?
            #234912
            Rusted Junk
              Yup it’s the same stuff.
              #234917
                Jim,
                Took thr thoughts right out of my head! You know that label has never changed. Good to get a post in, Been so busy retiring.& not wheels!!
                Jeff
                #235516
                Jackson65
                  Yeah, that’s my fault. I know if is Marvel Mystery Oil, but I have fallen into calling it Miracle Oil because it does seem to work miracles at times. Sorry for the misnomer.
