Home Forum Ask A Member Correct spark plug?
  • #246780
    elgin2
      I have a `97 25hp Johnson with a RJC8 and a JC8 spark plug. Which is the correct plug or are either the correct plug?
      #246781
        Did you Look on Marine Engine? Maybe you can figure it out from there.
        http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1997&hp=25&model=BE25AREUR
          Two cylinder or three cylinder?
          Two cylinder call for Champion QL77JC4, QL82C, or L78V. NGK equivalents would be BZ7HS-10, BR7HS, or BUHW-2.
          Three cylinder motors use QL86C or BR6HS plugs.
          NGK plug numbers with a -10 suffix means the plug has been gapped at the factory to 1mm, or .040″.
          #246803
          David Stanton
            I recommend the NGK BZ7HS-10. I’ve found Champion’s quality to be questionable in recent years.
            elgin2
              I wish it was 3 cylinders. They’re about as rare as hens teeth. It’s a twin.
