Home › Forum › Ask A Member › Crank seal replacement
  • #260028
    James Calamon
      1970 Evinrude 33 / 33053m Have engine out and doing everything but crank seals, but wanted to know how hard it would be t replace them and if there indicators for leaking crank seal. Bought motor sitting sideways in the back of a boat i bought, so I have no history. It shows some lower end work, but has original coils and ignition parts.
      #260030
      Tom
        Put some oil on the crank at the seal and turn the motor over, assuming reed plate is in place.  If you see bubbles, replace the seal.
        T
        #260033
          Here’s how I test the top seal for leaks while spinning the motor over with a wrench and the plugs out.
          https://youtube.com/shorts/cXt6fV6Z5rc?feature=share
          #260409
            Your statement  …doing everything but crank seals…  confuses me.  Do you have the powerhead all apart?
