Home Forum Ask A Member Disassembling an early Johnson gear foot?
  • #250707
    davidk
      Any guidance on how a Johnson Model A gear foot comes apart (and goes back together?
      IMG_6108
      #250710
        Most is obvious except –
        1-Take out the prop shaft.
        2-Turn the prop shaft gear so teeth are up
        and it will slide under the drive shaft gear.
        3-You have the slide this spring cover out
        of the way (big PITA!!!) to get the pin out
        to remove the drive shaft gear & driveshaft.
        #250711
        davidk
          oh, so the prop shaft should be able to be pulled from the gear? I expected that to be pinned and I couldn’t figure out how to get past the drive shaft pinion.
          Water pump should be able to pul from the gear foot housing when the set pin is removed?
          Thans Tubs!
          -David
          #250727
            The piston of the pump runs on the cam on
            the back of the gear so remove it first. Only thing
            holding it in is the set screw with the lock
            nut. They are usually tight and you have to
            wiggle the pump to get them out.
            The gear is keyed to the prop shaft.
            • This reply was modified 4 years, 5 months ago by Tubs.
            #250734
            davidk
              I wrestled with that prop shaft all day and couldn’t get it to relent. It was dry in there so maybe there’s corrosion? I’m soaking it in PB Blaster now. Someone, in the last 97 years, took the time to clean out the grease from the gear case and never refilled it. As a friend of mine likes to say “The enemy has been in here.”
              Thanks, Tubs, for the guidance and for the parts display. Very helpful. -DK
              #250873
              davidk
                Well, got it apart finally. Easy to see why it wasn’t parting easily. What a difference between these two lower units! The corroded cam chewed down the water pump piston. The last few runs of this motor might have been short with some rowing back to dock.
                IMG_6123
                IMG_6125
                IMG_6126
                IMG_6127
                #250879
                  Looks like that one struggle to stay alive until it’s last breath!
                    Its a testament to those old Johnson’s. You
                    would think it would have quit running long
                    before it got to that point. Its not that uncommon
                    to find gear cases in that condition in motors
                    that don’t have seals. What frustrates me even
                    more than opening up one and finding that is
                    one with a really nice set of gears. Except for
                    a few teeth at the bottom of the prop shaft gear,
                    that are mostly gone, from sitting in water for
                    decades, because they didn’t bother to drain the
                    gear case the last time they used it. How did
                    you like the spring cover on the drive shaft gear Dave?
                    #250881
                      Sometimes it’s amazing what you’ll find when you open up one of these old motors!
                      1982 Evinrude 25hp
                      #250888
                      davidk
                        That spring cover was no picnic Tubs! I marvel at the engineering of these old Johnsons but that spring cover is the kind of cruelty I usually find only in Mercurys.
