In the past, I have modified a few modern, readily available impellers to fit an application where the originals were NLA. I have had some success with this, even though my methods have been crude. This is because the impellers I was modifying were not very tall. Now, I would like to drill a hole to enlarge the shaft diameter of a taller (about 7/8″) impeller. I had a used one to experiment with and my hole came out off-center and crooked, even though I used a drill press. Have any of you guys had better luck? If so, how did you do it? Thanks.
Note: In particular, I am going to try to replace an automatic trans. Mercury impeller with one from a 9.9/15 Yamaha. As some of you know, those impellers take a bad set, even when relatively new and become useless in a few years, even if not even run. My idea is to use the Yamaha impeller, which has a better, more pliable and flexible material, and is darn close to the right overall size, except the bore.
This topic was modified 6 years, 5 months ago by
billw.
