Home Forum Ask A Member Early Honda BF100 with points
  • #225812
    mercuryman
      MY BF100 has weak spark won’t start even when I gap points to .010. I rigged up a military surplus 2 spark coil with a 7.5 volt battery and the engine runs good. So I have a bad coil or exciter coil.
      Anyone know what voltage to look for from the exciter coil. Thanks
      #225844
        bf100 manual… go to the top URL in the picture below
        #225863
        mercuryman
          Thanks, but Flash Player is blocked on my Browser I will have to fine a workaround.
          #225864
            go to parameters logo top right … select the * logo for parameters at the bottom of the list
            select cookies and authorization of sites on the left of the page
            select adobe flash
            move the button to ON and then everytime you reach a Adobe Flash site syst it wil ask you for permission to open
            but as of 2021 I am not certain it will work looks like Microsoft is dumping the application ???
            #225865
            mercuryman
              I think Boatinfo has the problem , I tried three browsers and cell phone and get the same message ” Flash Player 9 required” I have Flash 32 and as of December 31 Flash will no longer work.
              #225869
                ho well … i had no issues try this link see if you can work back up the library after you are in… hopefully
                https://bit.ly/2wqMPTb
                #225870
                seakaye12
                  If you go to iboats Honda forum and do a search for bf100 you will see a couple of posts there offering to e-mail you a Honda Service Manual. Some of them are old posts; but it might be worth a shot.
                  Here’s one example:
                  https://forums.iboats.com/threads/bf100-shop-manual.506010/
                  Generally speaking the iboats HONDA forum is pretty active; you will probably get your questions answered.
