Home Forum Ask A Member Early Johnson P & K crankcase
  • #200196
    MARC A. HAMER
      Hi all,
      Does anyone use some sort of sealant between the 2 portions of the split crankcase?
      Thanks.
      Marc
      #200198
        If the sealing surfaces are clean and straight, I think I’d use Permatex Anaerobic Flange Sealant, P/N 51531, on it. This stuff is similar to the old OMC Gel Seal and since it is anaerobic, it will set up in the absence of air. Permatex does have a copper based primer to compliment it if you are in a hurry but it will set up overnight without it.
        https://www.permatex.com/products/gasketing/anaerobic-gasket-makers-flange-sealants/permatex-anaerobic-flange-sealant/
        #200222
        Boggs74
          On the 1925-29 Model K and P
          I believe your looking for gaskets.
          If you do not use the correct thickness, it can cause crank shaft endplay issues.
          #200233
          MARC A. HAMER
            Thanks Yall
            #200237
            stanley
              Brown wrapping paper,shellacked then cut to shape works and is lose to original.
              #200300
              JOSEPH BRINCAT
                Yes, like Stanley said, brown paper… I use the common brown paper grocery bag… Good stuff. I usually give it a light spray of gasket sealer, both sides… let it dry thoroughly before installing.
                #200387
                MARC A. HAMER
                  Thanks. Originally there s no gasket between the top and bottom portions of the crankcase. Adding a paper gasket will mess up the crank shaft play… have you had success adding a gasket between the split portion of the crankcase?
                  #200411
                  stanley
                    Here’s parts list for P35 showing gaskets in question. #17-44,17-45. All the early opposed twin Johnsons I have worked on have these thin paper gaskets.
