I have an Elgin 2 hp with a Tillotson MD59A
carb that needs a sediment bowl.
Would anyone have a resource for parts or even a suggestion for a replacement carb
If that has the “tin” or “glass” sediment bowl, I’m guessing other model Tillotson carbs
use the same bowl.
Do you have the old damaged bowl, or is it missing?
If you have it, a photo with the diameter may help.
Also, if you haven’t already, post a free ad here on the Classified.
EBay may be an option.
I’ll look tomorrow to see if I have any loose Elgin carbs with a glass bowl
that size. There was a Gazillion Elgin’s made, so it shouldn’t be too
hard to find one.
P.S.- I looked this morning and did not find any extra glass bowls. Only
seen one on a “future project”, but on a larger Elgin, and with a lot
taller bowl that you describe.
Did you put an ad on the Classified here?
This reply was modified 4 years, 8 months ago by Buccaneer.
