Home Forum Ask A Member ELTO PAL RESTORATION
  • #190356
    William S. Hensley
      Does someone know who I can contact to restore my Elto Pal outboard motor? I’m a new member and not sure how things operate via the organization.
      Thanks,
      Bill Hensley
      williamhensley01@hotmail.com
      #190517
      outboardnut
        Maybe you would like to try to do it yourself?
        PPl on here will help you with advice.
        Just start asking questions
        #190524
          • This reply was modified 6 years, 2 months ago by Tubs.
          #190532
            Disappeared post
            #190534
              They were build for light weight and low cost. They did not take kindly to abuse. The most common broken part is the skeg on the bottom of the gear case. Gaskets may be cut from gasket material. The cork bumper in the check valve carburetor may be found in the canning section of a SuperMarket. Many adapt the Mercury float sold by Sierra Marine (i8-7208) if the old cork float is bad. The cork float was originally sealed with shellac which dissolves in todays alcohol containing fuel. If good, it would have to be resealed with fuel proof dope or super glue. The gear case takes grease. John Deere Corn Head Grease or white Lithium based assembly grease is used.
              #190537
                fifth try –
                #190539
                  eighth try –
                  #190540
                    ninth try –
                    #190542
                      eleventh try –
                      #190545
                        Thirteenth try –
