Home Forum Ask A Member Elto Senior Speedster
Viewing 10 posts - 31 through 40 (of 43 total)
  • #75633
      quote Dan in TN:
      Maybe I can find a Quad flywheel for it? I hear that advances the timing?
      The fuel mixer (carburetor) has no butterfly to control air/fuel mixture.
      You could consider it wide open all the time and has no effect on
      controlling the speed of the motor. The speed is controlled by advancing
      or retarding the timing with the "timer". Getting a flywheel that
      "advances the timing" would only change the position of the timer
      from its normal running position if the motor would run at all
      depending how far it would move the timers location for the motor to
      start and run. I don’t know if the Quad flywheel timing is the same or
      different than what you need. I would try a single knob service Speedster
      flywheel if you want to get it running. I don’t know for sure that the timing is
      the same so it will work but there are plenty around so I’m sure someone
      would let you borrow one to try. Having a water pump may take away from
      its performance slightly compared to a service Speedster. I have 2 service
      Speedster’s and on a 12" V bottom aluminum boat one will do 18 to 19 and the
      other 19 to 20 mph. I really enjoy running them and they are fast enough to
      make a good breeze if you know what I mean. This is the slower one but
      I have added extra baffles to the exhaust to quiet it down a little.
      https://www.youtube.com/watch?v=5GRrmslnz2A
      #75650
      ftruntz
        The 905 uses a ‘29 Quad flywheel. A Speedster flywheel is a different size crankshaft and will not work. The high speed versions of the Speedster, ‘28 Quad and ‘29 Quad were made with flywheels having seven degrees more advance. The 905 Special Speedster will benefit from using a ‘29 Quad high speed flywheel. But…lots of luck finding one. I ha
        ve been looking for some time with no luck
        Fred
        #75654
          The only way I can see that it could be of any benefit is
          if the gas tank blocks the timer from getting full advance
          with the stock flywheel. Please explain.
          #75657
          ftruntz
            Exactly what happens
            #75660
            PM T2
              quote Dan in TN:
              Well PM T2 we’re keeping the thread going. All over the place, but it’s going! Sorry for sorta high jacking things, but I did forget mine was a Special. I have another motor I’m not sure about, but got to get a decent picture.
              Dan in TN
              No worries, its the sort of conversation that I like to see kept going.
              PM T2
              #75676
                quote FTruntz:
                Not being able to get to full advance will
                defiantly have a negative on effect performance.
                I didn’t realize the Service Speedster and the High
                Speed Speedster had different crankshafts.
                Learned a lot. Thanks for responding.
                #75690
                ftruntz
                  The Speedster and Hi Speed Speedster have the same crank, the flywheel advance is the difference. The 905 Special Speedster uses ‘29 Quad hi speed cylinders, ‘29 Quad flywheel…..with a crankshaft having a larger taper to fit the ‘29 Quad flywheel, Senior Speedster muffler and ‘29 Quad lower unit. Sorry if the crankshaft for the Speedster got confused.
                  #75716
                  rexcars
                    Mine has an X which I was told was added when it made it back for repairs. Not sure how true that might be.
                    bill-loveland
                      I’ve seen that before. Looks like the original numbers were stamped by a drunk 😆
                      #75765
                        Might have been a Friday after they had gone out for lunch and cashed there paycheck at the local bar . . . 😆
