Home › Forum › Ask A Member › Evinrude 10 update
- This topic has 4 replies, 4 voices, and was last updated 3 years, 10 months ago by
Bob Wight.
May 16, 2022 at 2:30 pm #259960
A while back I posted a question regarding gas / oil mixture leaking around the hole where the shift handle goes into the midsection. There was not much response because this was such an unusual problem. I was talking with an AOMC buddy and he suggested I open up the crankcase and reseal. I got the correct gel seal and activator (that in itself wasn’t easy. Part stores look at you like you have 3 heads and then say thread lock is what I must need.) Anyway, I split the crankcase, cleaned it up real well and resealed with the gel sealer. Put everything back together and it cured the problem. Now this motor starts on the second pull, idles down to nothing and generally runs great. I’m looking forward to trying it on a boat soon. I thought some of you may benefit from this report.
May 16, 2022 at 2:41 pm #259965Good info thanks for the progress report…
2Fast4Me
May 16, 2022 at 8:29 pm #259967I don’t understand why resealing the crankcase would stop a leak on the shift handle. The shift handle shaft only requires a new O-ring to stop a leak at that point.
May 18, 2022 at 7:27 am #260011The powerhead sits above the area where the shift handle mounts. If the crankcase isn’t sealing properly it will leak gas / oil into the area below it, which is the mid section of the motor. The path the gas took was onto the shaft that goes from the shift handle into the mid section to the actual shift linkage. Some gas probably went straight down but some caused a steady drip from the shift shaft area. It also caused a lean run situation for the engine since fuel was being diverted from getting into the cylinder. There is no need for an o-ring on this shaft because normally there would be no reason to seal it up. It just gets grease to lubricate the shaft.
May 18, 2022 at 7:44 am #260012You do need an O-ring on the shift handle since some unburned fuel/oil mix in the exhaust stream or cooling water can escape out of the midsection thru the shift handle shaft.
This reply was modified 3 years, 10 months ago by
Bob Wight.
