Home › Forum › Ask A Member › Evinrude 35 hp control or electric maybe late 80s
- This topic has 15 replies, 4 voices, and was last updated 7 years, 9 months ago by
mgsolakis.
July 4, 2018 at 1:15 am #78993
Well, you would hold the black plastic latch in place on the warm up lever, then drill the two holes through the openings in the black plastic latch through the top half of the warm up lever. No need to drill through both sides of the warm up lever, that detent ball set up should just be pryed out so the plastic filler can be slipped inside for the latch screws to thread into…
Feel free to email me pictures of the other control box you are considering.July 4, 2018 at 2:08 am #78995Fleetwin I believe he may have a control box earlier than his engine? He may need this kit #396123. NLA, but some on eBay. At least you get to see all the parts needed. His original lever may not have enough space/length for holes to be drilled?
http://www.marineengine.com/newparts/pa … %3C%2Fp%3E
Kit shows parts needed for update.
https://www.ebay.com/itm/BRP-IMC-Johnso … SwdoJbO89q
Other kits/parts are available on eBay for different prices.
Dan in TN
July 4, 2018 at 12:20 pm #79007Thanks Dan, that kit is exactly what he needs! Please order this kit from ebay and you should be all set, then we can work on finding out why the engine won’t shut off properly…
July 4, 2018 at 1:23 pm #79011Thanks to both you guys hopefully it will ship up to Canada. Maybe I can beat the tariff war if I order it quick haha. I sent a picture of that other control I have to you Don. I’ll repost once the control is sorted and let you know about the not turning off issue. Maybe the control will solve it and maybe not. Thanks again.
July 4, 2018 at 7:56 pm #79036OK, I could not upload the pictures of the alternate control box Mike emailed to me…In any event, it was the older style, which will fit and work, but these older boxes have the same inherent problem as Steve’s current control box. So, I wouldn’t mess with it unless it was being sold for less than the repair kit for his current box.
The only benefit to trying another box is to find out whether the engine shuts off properly with it. If the engine shuts off properly with another control box, then we can assume there is a wiring/key switch problem with his current box.July 4, 2018 at 9:14 pm #79039Okay sorry I replied to your email but I’ll reply here as well so that anyone following can learn as well. Now I understand what you mean as well. The old box is no good but it would tell us whether the control on the boat is faulty.
