Home › Forum › Ask A Member › Evinrude Fisherman 6
- This topic has 7 replies, 6 voices, and was last updated 3 years, 10 months ago by
Don.
April 28, 2022 at 6:36 pm #259135
Evinrude Fisherman 6002 1970 It started and ran well several years ago. A good friend’s son is interested in it. He is said to be moderately competent DIY type, Other than replacing the plastic gear in starter I have left it be. It has been in dry heated basement for several years. Is the Fisherman 6 an easy motor for a novice to do TLC on,,the usual ignition, carburetor and impeller. Does it have the Universal Magneto, thermostat or special procedure required rather than a have at it approach. May run just fine as it stands, but, things do go stale just sitting on a rack.
Thanks
April 28, 2022 at 7:24 pm #259138nice easy to maintain simple design but…. one must learn how to take care of it under the FW… the rest is oil in the GC (check for water) and carb clean up
again.. all is easy when you know how
Johnson (leeroysramblings.com)
Outboard Motor Carburetor Repai (leeroysramblings.com)
Maintaining Johnson 9.9 Troubleshooting (leeroysramblings.com)
Rebuilding the OMC Fuel Pump (leeroysramblings.com)
April 28, 2022 at 9:01 pm #259143Nooo problem for you Louis! Most Ignition parts are similar same impeller and shock absorber I think. Although that rewind can make a preacher cuss! Somewhere in those years the points changed but you probably don’t need new ones anyway.
dale
April 29, 2022 at 9:19 am #259156Perfect engine for a novice for sure.
May 5, 2022 at 10:33 pm #259457I have one that I’m working on now. These are simple, almost bullet proof little motors even for the novice.
May 6, 2022 at 6:05 am #259459Might be the best running 2 stroke engine ever made. I don’t think a 1970 model had the shock absorber. Universal mag. It might run as is, might need points cleaned or might even need coils….it all depends on what was in there to start with and how long it was there. The thermostat (if somebody left it in there, I hope) is good for idle speed stability. I’d a least put it in boiling water to make sure it opens and closes. A new one would be best but they are costing up towards $50 in some cases, these days. Lower crank shaft seal system has the spring and cross pin arrangement. You have to turn the drive shaft as the lower unit is dropped to change the impeller, or you will bend a small roll pin on the drive shaft. You technically don’t have to pull the power head to change the impeller anymore; but if you do pull the power head, you can be much more assured that the lower crank shaft seal is in good shape and not damaged. Make sure you tell the new owner to be very careful of the shift handle. Do NOT lay the motor on that handle! It is very fragile.
May 6, 2022 at 8:50 am #259461the six has a carbon seal under the ph… just like this 5.5 (only 6-7 bolts to remove, fuel line and a link)
be very careful not to drop it ..it is carbon and fragile… the base gasket has a specifiec design choosethe part # carefully if you need to change the one on place…(if broken)
This reply was modified 3 years, 10 months ago by
JACQUES.
May 6, 2022 at 9:16 am #259467Might be the best running 2 stroke engine ever made. I don’t think a 1970 model had the shock absorber. Universal mag. It might run as is, might need points cleaned or might even need coils….it all depends on what was in there to start with and how long it was there. The thermostat (if somebody left it in there, I hope) is good for idle speed stability. I’d a least put it in boiling water to make sure it opens and closes. A new one would be best but they are costing up towards $50 in some cases, these days. Lower crank shaft seal system has the spring and cross pin arrangement. You have to turn the drive shaft as the lower unit is dropped to change the impeller, or you will bend a small roll pin on the drive shaft. You technically don’t have to pull the power head to change the impeller anymore; but if you do pull the power head, you can be much more assured that the lower crank shaft seal is in good shape and not damaged. Make sure you tell the new owner to be very careful of the shift handle. Do NOT lay the motor on that handle! It is very fragile.
I would agree, this engine was one of the best running, most durable, easy to service outboards ever produced by any manufacturer. Yeah, they are good trolling motors, not much for WOT power though. Listen to Bill’s advice about pulling the powerhead to check the lower seal components, and no stupid driveshaft shock absorber on these engines. And yes, be very careful with that shift handle, easily broken, and expensive to replace.
