Home Forum Ask A Member Evinrude Linkage Reversed?
  • #180455
    MARC BOUCHER
      I was putting together the linkage for my throttle and gear shifter for my 1964 40 hp Evinrude last night after working all weekend fixing up my boat and putting together the throttle box (correct term?) was the last part of this project. Couldn’t wait to get the boat back in the water.
      However, I noticed that something wasn’t right – it seemed that when I went forward with the throttle lever, it was moving the throttle on the motor the wrong way – exact same thing with the gear shifter. When I went to put it in forward, it was actually putting the motor in reverse. I’ve put these boxes back together dozens of times and this has never happened before. I’m stumped and embarrassed. Does anyone have any suggestions as to what I am/was doing wrong?
      Any advice is appreciated!
      -Marc
      Boats: '47 Dunphy, '64 Starcraft
      Motors:
      '53 Evinrude 25; '54 Evinrude 7.5; '55 Evinrude 7.5; '56 Evinrude 30 Lark; '56 Evinrude 16; '58 Johnson 18; '60 Evinrude 10; '64 Evinrude 40
      #180456
        What kind of control do you have, a Morse? That is the only kind that I know of that can be assembled to work backwards.
        #180459
          More likely, you have the throttle cable connected to the shift and vice-versa. That would work backwards.
          #180476
          MARC BOUCHER
            Oh my goodness – you are right. I had the cables reversed! Yes, it is the normal Simplex controls… Well thanks for the simple idea for me to check – I can’t believe I did that and then told all of you on this list!
            Motors:
