Home Forum Ask A Member Flambeau question
  • #194481
    davyray72
      How do I separate the carburetor from the gas tank on a flambeau 5 hp model 174050. I’ve seen the exploded diagram, but it’s not intuitive.
      Davy Ray Bennett
      #194497
      David Bartlett
        You need to remove the cover over the needle valves, then remove them. Remove the primer/fuel shut off, and it will come apart.
        I may have forgotten something as my motor and manuals are in storage.
        David Bartlett
        #194605
        green-thumbs
          As seen at 2016 Suter Meet…a Flambeau with all its secrets revealed.
          #194628
            Maybe I’ll work on my Flambeau next…… that cut-away gives me inspiration!
            It’s “stuck”, and I’ve squirted penetrating oil in the cylinders a couple of times
            over the last couple of years. I don’t even know if it’s the pistons stuck or
            lower unit, drive shaft, etc., but it looks like, assuming one can get the bolts
            out holding the halves together, getting “whatever” unstuck shouldn’t be too
            bad.
