Home › Forum › Ask A Member › Fogging Oil Life
- This topic has 5 replies, 5 voices, and was last updated 10 years, 8 months ago by
jw-in-dixie.
June 30, 2015 at 12:55 am #1894
An 80 plus year old friend of mine has an old Sears 12HP (West Bend) motor sitting outside on his aluminum boat. He is in the Nursing home and will never use it again. I ran it for him about 3 years or so ago and fogged it good then. How often should I be fogging it? I’d like to keep it operational so his daughter can sell it when he passes. He won’t part with it now and says he will be going fishing again soon.
His daughter won’t let me move it inside for some reason. She is his only child.
Thanks,
BillJune 30, 2015 at 1:24 am #19189Well first off good for you! What a friend you are.
with the winters here in canada the way they are, I do m ine every year to protect the bearings from damage.
June 30, 2015 at 3:49 am #19198I will say that you are a great friend! I would think that especially if it has been outside, I would run it ASAP. I don’t know how the fuel system is after that long of a rest, but the quicker you can get it running, the better off it will be. See if it pumps water, use fuel with sea foam stabilizer in it, so any residue will at least have some chance of not turning into green junk. Get it up to normal temp, run it forward and reverse. Then fog it up again!
Steve
June 30, 2015 at 10:34 am #19204There is so much going on in a motor that is left
outside. Moisture is getting into the mag, all the
fasteners, and everything that need to move.
It’s hard to understand how those who value
something so highly they won’t part with it yet
they don’t care for it.
I prefer adding extra oil (like 16 to 1) to fogging.
It should be just dripping with oil inside when you
shut it off. I’m presently running a motor I haven’t
used since 2002 or 2003 but it wasn’t left outside.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
June 30, 2015 at 2:08 pm #19213Thanks guys!!
I’ll try and run it with 16:1 and then fog it again. I’ll also change the lower unit oil. I changed it when I ran it about 3 years or so ago.
I’ll try again to get it inside the garage and off the boat. His daughter is very sensitive to dealing with his home possessions since he finally is settled in to the Nursing Home. It was quite a battle getting him to accept his fate.
BillJune 30, 2015 at 8:36 pm #19237I can understand the battle!! 83 and was out in the runabout with Bob yesterday, dadgumit!
Just wait til they try to stuff me in a home – I’m gonna go live on cruise ships!JW in Dixie
