Home Forum Ask A Member GoodyearSee Bee
  • #176528
    benji41
      looking for general info fo model 025-3562 sea#216381. Like spark plug, points setting, carb info, and lower unit info.
      Jim Benjamin
      #176530
        1948-49 Gale model 1G5, 1.5hp. J-8-C Plug .035 gap (I think). Points .020″. Tillotson carb. Russ Larson, The Martin Guy, has kits. Lower unit take grease. Lubriplate 105 or John Deere Corn Head Grease. They always leak, re-grease often. Water pump rotor is available from Brian Wilcox call 810-794-7685 before 8 pm est please.Or email Baron0418@att.net. please note the b must be a capital. Grease leaking out of lower unit destroys the pump rotor. I have a fix for that.
        #176558
          That same OMC powerhead was used on the Evinrude Sportsman in 1948 through 1951. In my opinion, one of the finest singles ever built. The spark plug gap is 0.030″. – this may help
          IF it has an auto- rewind starter, it won’t have this housing, BUT the internal parts are pretty much standard.
