Home Forum Ask A Member Grease for rewind starter
  • #8462
    captchuck
      You guys getting tired of my questions yet?
      I have the rewind starter for my Merc Mark 25 pulled apart and almost cleaned up. Now that it is time to assemble it what should I use for grease? The manual says ‘MULTIPURPOSE Lubricant (92-30239). What is that in human speak? White Lithium? Never-seeze? 105?
      Those 3 would be my guess but hopefully someone knows what they think would be best.
      #66150
        Good question. Not sure of the best answer. I’ve just been using
        a little Lubriplate 105. Some of them old starters just ooze
        black gunky grease out or have hard clumps of petrified grease
        in there. At least Lubriplate starts out "white"!
        greg-o
          I like Lubriplate 105 for these kind of applications. Gun grease has too much viscosity, and can get sticky with time.
          #66155
            I use mercury muli grease but VERY LIGHTLY. don’t use to much of what ever you use.
            #66167
            david-bartlett
              quote Dave Bernard:
              What Dave said. Very little is needed.
              #66168
              captchuck
                Thanks guys, used 105 SPARINGLY. Basically that’s what I had around the house, just a thin film worth.
                #66178
                  105 is okay. Those recoils can’t take a joke with excess binding of any sort; so I usually clean them very well….even using sand paper on the spring if need be….and assembling with 90 weight gear oil, again, sparingly. Works for me, anyway.
