Home Forum Ask A Member Help: Cant pull Lower unit on Johnson QD 10
  • #266903
    RickV
      Hi, I am new at this , trying to pull the lower unit off my Johnson QD 10,  I took off the 7 screws, as pics show, the lower unit comes down about 1 inch but it wont come off.  Can someone tell me what else I have to do, any help appreciated.  Thank you
      • This topic was modified 3 years, 6 months ago by RickV.
      #266908
        did you disconnect the shift shaft ??????
        #266909
        RickV
          I did not as I am just learning.  I will try to google it up, if it is easy and can be explained quickly, let me know.  Thank you
          #266921
            see pic
            one the side of these old motors is a small plate
            behind the plate is a clip holding the shift rod upper to the lower section..
            you must  loosen  the lower bolt enough to slide out the lower shif rod portion
            #266924
              Rick…  as a member  go to the MEMBERS ONLY tab
              select INNER SANCTUMN
              SELECT  LIBRARY
              SELECT GARRY SPENCER’S DROP BOX
              go down his list of  pics and links till you fing the RED BOOK  JOHNSON SERVICE MANUAL
              you just download it and print locally for safekeepiing    ALL THE INFO YOU NEED is in the book
              #266927
                see picture from that manual
                #266946
                RickV
                  Thank you Crosbyman, much appreciated
                  #266947
                  RickV
                    Just Downloaded,  Thank you
                    #266955
                      got mine  double sided printed at a local print shop and spring bound….with plastic cover sheets ………    for easy flat reading 🙂
                      #266958
                      Tom
                        Doesn’t the early QD require removing the rear cover and disconnecting the shift rod there?
                        T
