Home Forum Ask A Member how to remove float HS-15
  • #180880
    mabratton
      My johnson HS-15 float is held by a rectangular clip with a slot that has a firm grip on the needle. best way to remove this without damaging float or needle?
      #180899
      lloyd
        Remove the screw from the bottom of the float chamber. Find a pencil with a nice flat top soft eraser that will fit inside the hole against the bottom of the float needle to hold the float needle steady. Now using a needle nose plier, grasp the center area of the clip and rotate the clip while lifting it up and holding the float needle steady with the pencil eraser to keep the float needle shaft from rotating along with the clip. I have done it this way many times and it works.
        #180936
        mabratton
          Thank you kind sir. a little hot out in the shop right now but I’ll give it a go in the am.
          #180952
          mabratton
            the hole was a bit small for a pencil but a 3/16 wooden dowel worked well thanks again!
