Home Forum Ask A Member impeller replacement kits 5.5-6.7.5 ……hp
  • #228150
      https://www.amazon.ca/-/fr/r%C3%A9paration-763758-turbine-moteur-hors-bord/dp/B08DHJD9NM/ref=sr_1_18?__mk_fr_CA=%C3%85M%C3%85%C5%BD%C3%95%C3%91&dchild=1&keywords=omc+impeller+kit&qid=1611069851&sr=8-18
      these kits ( lucky mumbles $22 purchases) have jumped way up + shipping. They have a small diffrence with the OEM pumps from the 50-60’s
      I noticed on the one I purchased ( more $$$$ 🙁 ) that it does not have a vent hole drilled in the housing like the older ones have. Maybe the small hole is no longer needed.. ? .
      maybe it was OMC wisdom forgotten in the modern manufacturing process
      #228155
      Tinman
        Never have used one. Do they pump just as well?
        #228156
          Are these OEM kits??
          #228159
            They are offshore aftermarket kits but identical to the OEM kits in every way. I’ll check a housing for the bleeder hole against an OEM one later today. While I have one out, I’ll see if the country of origin is marked on the OEM box anywhere.
            This style pump first came out on the 1977 six horse motors replacing the old style, large impeller pumps. Since the water pumps are basically the same going back to ’54, these pumps will fit any 5, 5.5, 6, and 7.5 horse J/E from ’54 to ’79.
            • This reply was modified 5 years, 1 month ago by Mumbles.
