Home Forum Ask A Member Installing pistons in Merc 110 9.8 hp
  • #189313
    Douglas Follett
      I am having a problem keeping the rings aligned on the piston when installing in the block. What is the correct procedure? I already broke one ring.
      I have a Merc ring compressor and also a tube type.
      Sincerely,
      Doug Follett
      #189341
        call me 1 914 310 7086. Dave.
        #189362
          When you say, “I have a Merc ring compressor,” what exactly do you mean? The true Mercury built ring compressors for a 9.8 should be opposed finger-like devices, maybe 8″ long. You would need two to make quick work of a 9.8. You COULD do it with only one; but it’s harder. If you DO have these compressors, keeping the crank straight, square and level as it drops down is key. Also, a generous amount of two-stroke oil. The compressors look like this:
          https://www.ebay.com/itm/Vintage-Kiekhaefer-Mercury-Outboard-Motor-Piston-Ring-Compressor-Tool-Set-1950s/254195519774?epid=25030199583&hash=item3b2f3bd11e:g:GngAAOSwiolchT1g
          #189364
            Another key is well cleaned ring grooves. got pics of your compressors?
