Home Forum Ask A Member johnson 1929 model K45 7.15hp
  • #9076
      Motor has a compression relief lever – I know it how it works.
      it also has a relief lever for the exhaust – do I start motor with this closed or open and then run it open?
      #70197
      George Emmanuel
        Are you following the other K-45 post? The compression lever opens an exhaust valve to relieve cranking pressure on one (starboard) cylinder. It also closes the intake port so you crank the motor on one cylinder making it easier to pull over. Personally, I don’t use the compression release on my PR, PO, S-45 and V-45. I find them easy to pull over.
        George
        #160062
        10717
          Chuck–I have a K45 that is missing the exhaust relief lever on the handle and relief valve on the exhaust tube. Would you mind posting some close up pictures of these parts? I am particularly interested in what the valve assembly on the exhaust tube looks like. Thanks!
          #160079
          Tom
            Here are some photos of the actuator lever. This one was machined from parts cast by Art DeKalb.
            T
            #160129
            10717
              Thanks–I’ve recently ordered one of these from Art–yours certainly turned out well! Does your engine still have the original valve? All I have is the cover plate. Appreciate any tips you have on replacing those parts.
              #160138
              Tom
                Sorry, I’ve passed that motor on to a new owner. IIRC, there was a cone shaped piece that was spring loaded to close against the opening. I think Art’s parts come with a machining guide. Let me know if you need information regarding the sequence I used.
                T
                #160148
                Goman
                  This is what I came up with.
                  #160183
                  10717
                    Thanks!!!
