Home Forum Ask A Member Johnson AB-25 coil problems
  • #154883
    muddog2
      I got a new coil, old stock used, I took the ignition coil heel assemblys off my old coil and put them on the new coil I received and installed it on the armature plate. I put the flywheel on and it won’t turn a full turn around. It seems that the magnets are hitting the ignition coil heels. There is no ajustment and they screw directly into the armature plate. Any suggestions
      Thanks, Robert
      #154885
      stanley
        I use a marker to “color” the heels,then file the spots where the marker gets rubbed off of the heels
        #154902
          • This reply was modified 7 years, 3 months ago by Tubs.
          #154962
          muddog2
            Thanks, I did tap them in with a hammer, I guess I have to file now. I appreciate all the help here.
            Roberrt
