Home Forum Ask A Member Johnson HA39 idle adjustment
  • #274338
    beezer
      can anyone tell me if the hole on the crankcase idle speed adjustment is the same size straight through to the crankshaft or is it like a jet that is smaller in size as it goes to feed fuel to the crankcase?  it’s the adjustment behind the gas tank. mine is all stopped up and before i take a drill bit to it i would like to know if it is a different size the farther you go in the hole. i would think it’s a straight through shot to the crankshaft. thanks
      #274339
      lloyd
        It is basically the same size hole all the way into the crankcase except in the front of the hole where it tapers out.  This may lead you to believe that it tapers all the way in.  I would not use a drill bit to clean it out as you might use too large a bit and damage the correct size of the hole. In addition, the fuel mixture needle partially penetrates into the orifice, so using a drill bit can damage the needle. Try cleaning it out with a small diameter stiff wire and be sure to back out the mixture needle so it won’t get damaged.
        You will also surely need new leather primer seals and instructions to clean out and test the one way fuel valve that directs fuel to the low speed mixture valve. If so, contact me.
        Lloyd Lautner
        231-929-7479
        #274373
        beezer
          thanks for the info.  not sure if im going to try to start it . i have it all apart now how much do you want for the carb seals? thanks again.
          #274374
          lloyd
            For new leather primer seals and installation instructions send $10.00 cash (no checks or money orders) and a self addressed stamped envelope to me
            Lloyd Lautner  9289 North Long Lake Road  Traverse City  Michigan  49685
