Home Forum Ask A Member Johnson’s first use of rubber tiller grip
  • This topic has 5 replies, 4 voices, and was last updated 8 years ago by skeg.
  • #9200
    skeg
      Restoring some Model A’s and wondering when Johnson first starting using the rubber grip with their name on it? What are the years that the leather grip was used?
      Thanks much for any input.
      Skeg
      #70909
      PM T2
        To the best of my knowledge Johnson was using the leather-wrapped wood grip until 1926.
        I believe when the A-35 came out in 1927 that they switched to rubber grips. I cannot tell you if the Johnson name was on it or not, but I honestly don’t think that showed up until sometime in the 1930’s.
        FWIW I’ve seen many 1926 vintage A-25’s and P-30’s with the leather-wrapped grips, but never anything later.
        Hope it helps.
        Best, PM T2
        #70921
        skeg
          Thanks very much !
          Appreciate the input.
          Skeg
          #70929
          squierka39
            I don’t know about the 20’s but from 1930 to 1939 my Johnson’s with original grip are all rubber and none have the name script yet. On mine the name seems to start with 1940. Might have been earlier on other models I don’t know, mine are all K model Johnson’s.
            #70933
            twostroke
              I’ve got a K-35 and an OA-60, both of which I’m 99.99% sure have original grips. The K-35 is plain rubber, the OA-60 has the "Johnson" lettering on it.
              Jim
              #70969
              skeg
                Thanks for the input guys. Much appreciated.
                Skeg
