Home Forum Ask A Member Johnson serial number scraped off
Viewing 10 posts - 21 through 30 (of 35 total)
  • #185919
    hag
      Tubs, finished the conversion and I have spark! Nice not hard but some work for sure.
      Another question about the lower unit oil/ grease….should I use grease or the lubriplate? The lower unit not very water tight by the looks of it. Think normal grease less likely to flow out then lubriplate? Does it matter?
      #185921
        disregard
        #185925
          https://www.enginads.com/otto/
          • This reply was modified 6 years, 3 months ago by Tubs.
          #185926
            • This reply was modified 4 years, 11 months ago by Tubs.
            #185934
            hag
              Ok lubriplate it is then. Can’t find corn head grease around here.
              Another question. Adjusting the points on this thing. What is the best procedure? Is it cylinder one tdc ? Where should the spark advance lever be? I think it’s 0.020 (spark plug 0.030?). I need a quick run down please.
              I hope I’m not trying everybody’s patience but this is my first close to 100 year old motor. I like it.
              #185954
              stanley
                Most of the time all you have to do is clean the points and set them at .020.Doesn’t matter where mag handle is as long as they are fully open.Then you can look at bottom rim of fly wheel and find a factory mark,single groove.When points are just about to open,this should align with a similar mark on mag plate bottom.The mark on the mag plate is about 1/2 inch from the handle.If the marks don’t align exactly it will still run fine.
                #185956
                hag
                  Ok thanks Stanley
                  #185959
                    https://aomci.org/forums/topic/johnson-a-a25-plug-and-points-setting/#post-177942
                    #185960
                      #185963
