Home Forum Ask A Member KA-37 lower unit grease?
  • #297972
    Boonie
      Finished my resto on the KA 37. Plan is to use corn head grease for the lower unit. There is 2 plugs. One at the skeg and one above the cavitation plate. Question is what is the procedure for putting grease in? In the bottom untill it comes out the top hole?
      if so how much grease will it hold? And there is a third screw higher up that says drain?
      #297980
      David Bartlett
        Boonie,
        You are correct. Put in lower hole until it comes out the one above the gearcase. Will hold about a half-pint.
        David Bartlett
        #297981
          I’m picky. I turn the prop over a few times, then try to add some more grease to get rid of air bubles. Not ewquired but just me.
          #298018
          Boonie
            Thanks guys. Thats what i thought. Just seems to be a big cavity to fill. Hey David, Bear Kodiak? I have an archery collection!
            #298057
            David Bartlett
              Boonie,
              I have more than enough bows already. N+1.
              David Bartlett
              #298182
              Boonie
                N+1. ?
