Home Forum Ask A Member ke 7 or ke 7 lightning?
  • #219437
    ronboonville
      I saw a ke 7 for sale, what does the lightning mean?
      #219441
        • This reply was modified 5 years, 4 months ago by Tubs.
        #219447
          just the name of that model.
          #219466
          ronboonville
            thanks, thought it was something special.
            #219467
              like a nickname
              #219489
                It IS something special. Maybe more than any other motor, it put Mercury on the map for real, as a company.
                #219495
                49morphew
                  20201007_205329
                  The earliest models, supposedly about the first two thousand serial numbers were simply called KE 7. These motors have the square ID tag with no mention of the word Lightning on them. Same motor though.
                  #219519
                  JimJ
                    First model. Cast trim, rather than added stainless trim. Same motor other wise.
                    #219593
                    outbdnut2
                      KE7 Lightning is a Good Motor! I ran mine on a hydroplane for years, (not with special racing gears) revving higher RPMs than it was designed for. Only had to replace one reed. I double the oil in the gas and go one heat range colder on the spark plugs for hydroplane use on any motor I put on it.
