Home Forum Ask A Member KF7 WITH 8 REEDS
  • #264223
    Jorzo211
      So I’m rebuilding my KF7 and I want swap in a 8 reed cage, crankshaft with rods and pistons. The doner with be from a possible 20h case with all the goodies. Is this possible using the kf7 case?. I plan to port the intake on the block also.
      MARK-7, KF-7, KE4-A, MARK 15, WN7A, (60)MERC 200
      #264228
        why not just use the mark 20 powerhead?
        #264230
        Jorzo211
          I could but I need a carb, phelon plate, and either block off or put a fuel pump on the case and turn it into a pumper. But I honestly wanna keep the KF7 all together besides the original crank and reed cage. Plus I need to find a q or h tower with a the gear case. It’s on a service tower at the moment.
