Home Forum Ask A Member Lauson T-653 R Information Request
Viewing 10 posts - 11 through 20 (of 28 total)
  • #304246
    JOHN D.
      As far as cutting down the center pole, you will need to cut down both sides. This will allow the coil to slide on without interference. The John Deere coil is large enough and needs to slide in with at least 1/4″ of the center lamination sticking out. This helps to keep the flywheel magnets from hitting the coil.
      #304247
      JOSEPH BRINCAT
        jtr , using a Scott armature … that sir is a good bit of information to know. Thanks.  Is the Scott armature 1/2″  ?  .. the Pony Motor coil is 1/2″ square if I recall
        #304249
        JOHN D.
          It is more like 0.450″. I ground the rivets off the center pole and removed the coil keeper for clearance. Then I epoxied the coil in place. Hope it holds.
          #304275
          mas
            When I did the pony coil conversion…I remember needing to remove one or two laminations to allow the coil to slide on…the laminations are too thick.  Be sure to remove the top laminations (if needed) to allow the coil to sit lower for clearance.
            #304276
            mas
              Here are some pics of the conversion that I did over ten years ago with great success.  The pics were clipped by Tubs before our original website crashed and all posts were lost.  I’m glad he did that…Thank you
              #304279
              mas
                Pic 2
                #304281
                mas
                  Pic 3
                  #304283
                  mas
                    Pic 4
                    #304285
                    mas
                      Pic 5
                      #304287
                      mas
                        Pic 6
