Home Forum Ask A Member Leakdown vs compression testing?
  • This topic has 1 reply, 2 voices, and was last updated 7 years ago by rco.
  • #10494
    amuller
      I just read Joe McCauley’s article ("Leakdown, Break-in, Ring Seal, and Oil") in the most recent (July) Antique Outboarder.
      L learned to use a leakdown tester when working on airplanes, where they are standard procedure and ordinary compression gauges aren’t generally used. There is not much to them and you can get one for $25 or so.
      https://en.wikipedia.org/wiki/Leak-down_tester
      Anyway, wondering if others here have used these on outboards and with what results.
      #79238
      rco
        I have been a professional mechanic for 20+ years. Cylinder leakage tests are very valuable on 4 stroke engines, but I don’t put a lot of stock in the results on 2 stroke engines. You are only able to test the ring sealing surface in one spot in the cylinder which may be better or worse than the rest of the cylinder.
