Home Forum Ask A Member Leather primer seals
  • #220619
      • This reply was modified 5 years, 4 months ago by Tubs.
      #220626
      Michael Purpura
        Are those the leather seals that Lloyd sells? The photo with the two seals stacked on top of each other?
        #220629
        lloyd
          Yes. The red arrow is pointing at the Leather seals. When you order new seals they come with complete instructions and diagrams. I am happy to report that in 20 years no one has told me that they couldn’t make the primer work with a new set of seals.
          To check the one way check valve, clean it off so you don’t get junk in your mouth, Then put the end with the hole up to your lips. When you blow air should not pass. When you suck ,air should pass freely. If not the little stainless steel ball inside is stuck from old varnish. Soak the valve in Acetone and or lacquer thinner and blast it out with compressed air until it functions as described above.
          #220664
            #220672
            Michael Purpura
              Thank you Lloyd. I will need seals for the HS39 and the TN27. Can I prepay this by sending you a check from my bank and then when you cash it you send the seals? What is the cost for each set?
              #220673
              Michael Purpura
                Thank you Tubs. On this old HS39 would you advise me to take the engine apart completely or just go through the ignition, carb and lower end and then give it a yank?
                #220679
                  #220681
                    Hello. I am Lloyd Lautner. I have what you need. Send $10.00 cash (no checks or money orders) and a SASE ( Self Addressed Stamped Envelope) To me: Lloyd Lautner 9289 North Long Lake Road Traverse City Michigan 49685
                    #220844
                    lloyd
                      Michael, the order instructions are above in this thread. No Checks or Money orders. Cash only. $10.00 for each set and a Self Addressed Stamped Envelope.
                      #228074
                      Michael Purpura
                        Mumbles,
                        I don’t remember who mentioned that they were having trouble with an old HS series Johnson. There was talk of it running erratically. I can tell you I got mine running smooth as silk. The coil, condenser and points were good. My problem was the conductive graphite rods. I had to remake them. If you are having trouble and want to try new rods let me know and I will make a set for you. You certainly helped me get my engine running and I would like to return the favor.
                        Mike
