Home › Forum › Ask A Member › Looking for outboard for father/son building project
- This topic has 25 replies, 11 voices, and was last updated 7 years, 11 months ago by
outbdnut2.
May 8, 2018 at 2:45 pm #75555quote auldscott:Mercurys are like barely tamed horses, urgent and barely civilized, but thrilling. OMCs are polite and capable (which does not mean boring). Exotics like Scott-Atwaters/McCullochs are a bit mysterious, but they are good performers.
I admire your creative descriptions, and they are right-on! Kind of sounds like describing 3 different girlfriends!….Now, wives have occasionally referred to outboard motors as’"the other women" because of the amount of time we sometimes devote to them.
I have to go now and attempt to fix a "Mysterious Scott-Atwater" for a friend.
May 8, 2018 at 4:11 pm #75565Thanks for the advice gents!
While I love the thought of running it with a vintage motor, the draw to a more hassle free/reliable motor is there as well.
The other part is that I need to consider the budget 🙂 My son is half owner on this venture and we need to keep his costs down.At least we don’t have to have the motor until the end of July. So I have a bit of time.
One question though: short shaft or long? I haven’t cut the transom yet, and need to make a decision soon.
I’m leaning on going short.Thoughts?
May 8, 2018 at 5:27 pm #75571I would go long shaft. can ALWAYS go shot later much easier than the reverse.
May 8, 2018 at 10:08 pm #75584I’m a Merc fan, but save yourself some grief and $$ and get a later 50’s Johnson/Evinrude 18. They are quite common but there are really nice color combinations. They use the Universal magneto so the parts are common and cheap (compared to Merc). No surprise special tools needed. Water pump parts are cheaper, easier to find, less chance for a bad lower unit (Merc didn’t use stainless back then). If you like the Johnson/Evinrude, you can venture of into Mercury land in the future. YMMV
May 8, 2018 at 11:55 pm #75594If you are going where the waves get big, with a long shaft transom, you are less likely to take water over the back when idling in big waves or backing up.
DaveMay 9, 2018 at 6:17 pm #75641So I found a ’58 Johnson Sea Horse 18 for sale locally. It probably hasn’t run in a while. Are they hard to get back up running? Is $180 a reasonable price.
May 9, 2018 at 7:26 pm #75644I’m also near Seattle. The prices of old outboards are always a bit higher around here than they are in the Midwest where most of them were made, and probably a good portion of members here. I would say that $180 is reasonable as long as it has good compression and has decent paint, and is all complete. You will want to expect to pay about $150-200 to get it running. Maybe more, maybe less. Will likely need new coils, so be prepared to pull the flywheel. Impeller is a must. Carb clean with a new float is very likely. That short list is probably the minimum, and you’re looking at about $150 right there. Seaway Marine will be your friend. They’re up in Lynwood.
So, compare that to a motor that the owner can show you running, in this region, probably $400 minimum for a 1950’s 18hp.
May 9, 2018 at 8:09 pm #75647Thanks
May 10, 2018 at 1:37 am #75659I was a Merc fellow for nearly 50 years (3.9, 9.8, 20, 50, 45 ) went ETEC at 57 when I retired … great motor
but now i enjoy fixing up J&E oldies TN27 5hp up to mid 70s 9.5hps magneto ignitions only ….for me
easy to work on ( at my level anyway) parts available, and a good book to keep them going
May 10, 2018 at 3:11 am #75662Anonymous
Here’s some good reading for you. The second link is a series of articles
written for the home boat building folks about cheap power.
http://precisionservoutboard.com/about/ … oint-plan/
http://www.omc-boats.org/maxw.html
I have a ’57 Johnson 18hp that is my go to fishing motor.
Love it!
Good luck with your project.
Steve A W -
