Home Forum Ask A Member Magneto Cam and Timming Tool Question
Viewing 10 posts - 1 through 10 (of 43 total)
  • #303267
    Kent Cochran
      All,
      I am working on a 1952 Johnson 10 hp QD-13.  It will cough & spit but never start.
      I think i have a timing issue maybe???
      If i had a Timing Tool  and used it after setting the points with a feeler gauge, will the Magneto Cam (Top/high point) and Timing Tool line up together?
      I have set the points using a feeler gauge at .020. I have good blue spark on both cylinders. Should i try using a Timing Tool to reset the points? Maybe I need to buy one from Richard W.
      I Have good compression 70 psi on both cylinders. Cleaned and rebuilt Magneto it was very dirty. Cam, shaft, Key, and flywheel key way were very rusty. New plugs, wires, coils, condensers. Cleaned old points and reused.
      Completely rebuilt carburetor. it seems to be working as should.
      My two line pressure tank is also working as should. It holds 3 psi of pressure all the way to fitting for motor.
      Thanks, Kent
      Kent Cochran
      1949 10 hp Johnson QD-10
      1951 5 hp Johnson TN-27
      1952 10 hp Johnson QD-13
      1956 7.5 hp Evinrude 7520
      1957 7.5 hp Evinrude 7522
      #303270
        timing tool is an excellent investment but not used much  if you only have 1-2 motors
        just make certain the front coil HV coil  wire is on the top cyl. !
        update:  🙂 I guess you have more than 1-2   !!!
        download  the free johnson service manual if you don’t have a copy … print & bind locally
        https://www.socalaomci.com/library/johnson_service_manual_10th_edition.pdf
        http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
        #303277
        RICHARD A. WHITE
          All,
          Thanks, Kent
          I am heading to bed right now…4:30 am comes early. I will digest your comment tomorrow at work and muster up some answers.
          Regards
          Richard
          classicomctools@gmail.com
          #303280
          Kent Cochran
            Thanks, Richard
            Any advise will be appreciated.
            Kent Cochran
            #303281
            Kent Cochran
              Crosbyman,
              Thanks, for the information and advice. I will double check the coil wiring. I will send before and after photos later today of Magneto rebuild. I reinstalled everything like I found it. Not saying it correct.
              Kent Cochran
              #303282
              RICHARD A. WHITE
                All,
                Thanks, Kent
                Alright, lets get this started.
                Using a feelers gage, is not an exact science. You will get spark, just harder to guarantee ” WHEN” you get spark, and that is the issue.
                There are wizards out there that do it, but the timing tool removes all doubt, when used properly.
                The timing tool promises to give you spark, as long as all the spark making components are good, at the moment you need spark in relation to where the piston(s) are vs TDC. On 2 cylinder models the tool also ensures that if used properly BOTH cylinders are firing as close to exactly 180 degrees apart as one can get ensuring best chance for smooth idle. I think Frank Robb told me there are like at least 10 different timing cam lobes, and probably more variations, so comparing what the timing tool get you to the feelers gage, would be challenging at best.  Yes, some of them have the word “SET” on them. The makes an interesting conversation as where within that word “SET” do you stop and set the points?  I believe that is why the timing tools were developed, because of the wildly varying possibilities with the feelers gage. And to be quite honest, the timing tool is faster. Really fast if you use the high dollar squawk box from Aircraft Spruce, because with that you don’t need to disconnect any wiring.
                This may or may not answer your questions about your motor being hard starting.  My guess is carb…Why you say?, Because you have spark, on both cylinders, so if you don’t get fuel, it wont run.  Even if your timing is off, it will still run, just not well…
                That is all I got…
                Good luck
                Richard
                #303283
                  if you read the book  you will find that setting the points at .020  on the high point of the cam is generally sufficient.   It is more critical to have the points OPEN at the right instant .   .020 is a guide ..      openning on the cam markings in the video  makes it perfect.
                  if you did set them at .020 and cleaned them properly  your problem is likely elsewhere.
                  #303286
                    The best spark is achieved when the points open as the polarity of the magnet changes (normally from north to south – but not always) as it passes over the middle of the coil. The factory gap setting will get you very close as to when it comes time to do maintenance as most won’t have a timing tool.
                    #303287
                      A 10$ VOM  ,   a simple  test bulb/led   or small piezo buzzer  with a  9v battery is really all one needs  for a perfect job.  Series connected to the points
                      the bulb or buzzer going off will tell you when the points have openned…. just like a VOM does .  Adjust the point cam screw to line up the bars as per  the video.
                      if one is lucky to have an old Telco KS  meter  you don’t even have to disconnect any wires… the small needle swing makes it clearly visible  when the points open.
                      #303288
                      RICHARD A. WHITE
                        You are correct, but for one little buggar of an issue.
                        What method is used to determine, on the many different cams, exactly where the high point it is?
                        This is more than likely why they switched to using the timing tools for their shops, it is easier, faster and wholeheartedly more accurate.
                        One would literally need to set up each cam they have for each motor, if different, on a spindle and using a dial indicator to know “where” exactly that high point is.  There is NO visual marker, on any cam that I have seen that points to the exact spot, and it is a spot of maybe 1 degree of rotation on the cam, not 10 degrees or more like on one particular cam I recall seeing.
                        I am not in any way poo-pooing the use of feelers gages, I am merely pointing out that the use of the timing tool removes soooooo many other possible errors.
                        The “generally sufficient” comment, was before they developed the timing tools. But for me and my OMC’s, “generally sufficient” is not good enough….lol
