Home › Forum › Ask A Member › Mark 25 Magneto
- This topic has 10 replies, 7 voices, and was last updated 8 years ago by
tarcigam.
April 2, 2018 at 10:46 pm #9539
I replaced the coils in one about ten years ago. I have no recollection of what I used or where I got them. I do recall I had to pull them off the heals and remount them. Anyone know what I might have used? New ones seem to be rare and expensive if you do find them.
April 2, 2018 at 10:54 pm #73368https://www.summitracing.com/parts/smp-s3604
They don’t seem extremely expensive.
viewtopic.php?f=2&t=14760
https://m.youtube.com/watch?v=OxPHe8EPe1QOr convert it to omc coils.
April 2, 2018 at 11:16 pm #73369No one checks the caps or insulation values, great mags! Check each comonent, assemble & meter, Wax = bad dielectrics 60 years later š³
April 3, 2018 at 1:16 am #73377Not expensive. Did not find that. Thank you much.
April 3, 2018 at 1:24 am #73378$27 on Amazon.
https://www.amazon.com/Standard-Motor-P … B000JKC47I
quote tarcigam:Not expensive. Did not find that. Thank you much.April 3, 2018 at 1:37 am #73381quote david bartlett:$27 on Amazon.
quote tarcigam:Not expensive. Did not find that. Thank you much.Amazon is out of stock.
April 3, 2018 at 3:18 am #73390any source for coil for mark 20. scintilla 399-125 ?
April 3, 2018 at 3:17 pm #73404quote ronboonville:any source for coil for mark 20. scintilla 399-125 ?I think they found these to work…. But do not quote me on that..
viewtopic.php?f=5&t=15908&p=83508&hilit=Bendix#p83508
classicomctools@gmail.comApril 3, 2018 at 3:32 pm #73406quote tarcigam:I replaced the coils in one about ten years ago. I have no recollection of what I used or where I got them. I do recall I had to pull them off the heals and remount them. Anyone know what I might have used? New ones seem to be rare and expensive if you do find them.You can substitute the OMC coils with a little work.
https://www.youtube.com/watch?v=OxPHe8EPe1QA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
April 3, 2018 at 8:26 pm #73416Tubs,
bought a MK 25 15 years ago & was running early honda motorcycles. Guy didn’t even change the caps or match coils, Fit under too but needed a battery -
